PI 2.1 virtualization
gauthierboulet
Hi everybody,
I have a question concerning PI 2.1 on virtualization system.
For one of my curstomer, we have installed PI 2.1 on ESXi 5.1. Virtual Hardware is in 7 version.
My customer plan to upgrade on vSphere cluster to 5.5 version.
My question is : what's the impact on PI installed on ESXi version 5.1 on ESXi 5.5 ?
It's working or not ?
I think if we do the upgrade we loose support from Cisco ?
Thanks a lot for your answer
BR
Falk Fischer
the "virtual machine hardware version" will be the same after upgrading to esx 5.1 or 5.5.
It's a manual process on each VM necessary to upgrade he hardware version to a higher level.
greetings
Falk
We upgraded to esx 5.5 without any problems.
