PI 3.0 EoX and PSIRT Reports Help
daniel.litwin
Running Prime Infra 3.0.2.
Trying to generate PSIRT and EOX reports.  I have enabled complaince under settings,servers and rebooted the PI server.
I can see the PSIRT and EOX report listing under the reports tab.
I have syncd all my devices, as they do this nightly.
I clicked "Schedule Job" under the PSIRT and EOX screen.  Gave me the message about being resource hungry and to run after hours, etc.
When I click on the "Job Detail" button, it just says "Job detail is not available".  Status says "running".  This seems to run for like 10 mins, then stops.  I see no new reports under  the Device PSIRT, Device Hardware EOX, Field Notice, etc. tabs.
What am I doing wrong?
Thanks.
Dannon
16 Replies 16
That is the same process as me except that I installed 3.0.1 before 3.0.2
daniel.litwin
Turns out it is a bug: CSCux44760
I had to open a TAC case to get it resolved.
Reports are working fine now.
