PI 3.1.5 Compliance Policy "Evaluate Expression" Help
joshelton
Currently on Prime Infrastructure 3.1.5
I want to verify that none of the line configs (Line con, line vty) have an exec-timeout greater than 10. In most devices exec-timeout 10 is the default and won't show in the line config. So my rule exits if exec-timeout is not present. I'm having problems with my rule showing everything as compliant. Here is what I have:
Part 1 looks for blocks that start with line, so they can be later called for the fix-cli
Configuration
Parse as Blocks
Block Start = line
Matches the expression = line (.*)
Part 2 gets the value that is showin for exec-timout to send to the next rule and do an evaluate
Previously Matched Blocks
Matches the expression = exec-timeout (.*)
Part 3
Evaluate Expression = <2.1> > 10
Everytime I run the rule I get a return as compliant.
Brett
There are only a few things that need to get changed.
Part 1:
Block Start = line .*
Part 2:
Matches the expression = exec-timeout (.*) (.*)
***** We have to add the extra (.*)  to store the second value.  The exec-timeout command if configured has two values*****
exec-timeout 15 0
So we have to account for there being another value after what we want to capture. If we didn't do this the value that would be stored would be:
15 0 instead of just 15
Part 3:
In Part one if it matches continue, if it doesn't match select "Does Not Raise Violation"
In Part two if it matches continue, if it doesn't match select "Raise a Violation and Continue"
In Part three if it matches continue, if it doesn't match select "Raise a Violation and Continue"
Hope this helps
Brett
