PI recovery cli password error
CCC3
I lost the PI's cli account, mapped the iso to kvm, booted it, and proceeded with recovery by pressing 3 in boot options.
but
!!!!!!!! FAILED TO FIND ADE-OS STARTUP CONFIGURATION !!!!!!!!!!
!!!!!!!! UNABLE TO PROCEED WITH PASSWORD RECOVERY!!!!!!!!!!!
SYSTEM WILL RESTART
Press any key.....
Recovery did not proceed properly according to the log above.
Does anyone know a solution?
The version is version 2.2.
The model name is PI-UCS-API-K9
marce1000
 - FYI : https://community.cisco.com/t5/network-access-control/reset-ise-cli-password/m-p/1992335#M186645
 M.
tough one. I assume you are using the recovery procedure below ? What if you try '4' (console) instead of '3' ?
https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/prime-infrastructure/115609-ppr.html
