Port security enable/disable using snmp
Amardeep Singh
Hi Guys,
I am researching on setting the port segregation on the cisco switch using snmp. Is there any MIB that I can use to achieve this?
I want to enable/disable the port security on an interface / port.
It tried using the cpsIfPortSecurityStatus identifier, but it gives error:
snmpset -c private TEST cpsIfPortSecurityStatus.5 integer 1
snmp2_set(): Error in packet at 'SNMPv2-SMI::enterprises.9.9.315.1.2.1.1.1.10120': commitFailed
5 Replies 5
marce1000
 - FYI : https://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/15217-copy-configs-snmp.html
 M.
The above link shows how to copy over the configs. I want to achieve something different like I need mib/variables to allow me to set a trunk port and add/remove vlans on that interface.
interface GigabitEthernet1/0/8
switchport trunk allowed vlan 101
 - You can also use the procedures in the mentioned-link to upload/merge small configuration-snippets into an existing running configuration hence applying changes as you describe. There are no-direct mib-variables for  that.
 M.
I also tried using the cpsIfPortSecurityStatus for setting the status on the interface.
Example :
snmpset -c private TEST cpsIfPortSecurityStatus.0105 integer 1
But it gives the error -
'SNMPv2-SMI::enterprises.9.9.315.1.2.1.1.2.10105': notWritable (That object does not support modification)
 Please suggest.
 -  Verify/check  snmp rw community , also post switch model if problem does not get resolved
 M.
