SSH issue
yjdabear
This is after deleting the previously stored key from
/home/myid/.ssh/known_hosts.
debug1: sending SSH2_MSG_KEXDH_INIT
debug1: expecting SSH2_MSG_KEXDH_REPLY
debug3: check_host_in_hostfile: filename /home/myid/.ssh/known_hosts
debug3: check_host_in_hostfile: filename /etc/ssh_known_hosts
debug2: no key of type 0 for host router1
debug3: check_host_in_hostfile: filename /home/myid/.ssh/known_hosts2
debug3: check_host_in_hostfile: filename /etc/ssh_known_hosts2
debug2: no key of type 2 for host router1
The authenticity of host 'router1 (10.1.5.9)' can't be established.
RSA key fingerprint is 22:e3:6d:c1:12:be:0e:63:4c:77:0c:b5:67:74:c5:ae.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added 'router1,10.1.5.9' (RSA) to the list of known hosts.
debug2: bits set: 507/1024
RSA_public_decrypt failed: error:0407006A:rsa routines:RSA_padding_check_PKCS1_type_1:block type is not 01
debug1: ssh_rsa_verify: signature incorrect
key_verify failed for server_host_key
debug1: Calling cleanup 0x2d2e4(0x0)
There's no hardware change on the Cisco device.
"show cryp key mypubkey rsa" looks fine.
Never mind, turns out no SSH server is running on the router.
10 Replies 10
Joe Clarke
Just FYI, when troubleshooting SSH, the first thing I typically do is telnet to TCP port 22 on the target device. This allows me to confirm, first, that SSH is running, and second what protocol version is being used:
1.5 : The device only supports SSHv1
1.99 : The device supports both SSHv1 and SSHv2 (RME will use SSHv2 to communicate with the device)
2.0 : The device only supports SSHv2
In this case, it's answering on port 22, but "show ssh" indicates there's no SSHv1 or v2 server running.
%No SSHv2 server connections running.
%No SSHv1 server connections running.
The issue : RSA_public_decrypt failed: error:0407006A:rsa routines:RSA_padding_check_PKCS1_type_1:block type is not 01
is related to the cisco router. The RSA key are corrupted and you cannot connect on the router with a ssh client in SSH V2
To fix it
  • Enable telnet access on the router
    enable
    conf t
    line vty 0 4
    logging synchronous
    length 0
    transport input telnet ssh
    line vty 5 15
    logging synchronous
  • Suppress the RSA key present on the router by the telnet access
    enable
    conf t
    crypto key zeroize
  • Add a domain name on the router
    enable
    conf t
    ip domain-name XXX.YYY.com
  • Create a new key RSA pair
    enable
    conf t
    crypto key rsa modulus 2048
  • Reboot the router
since a router, don't forget a "wr mem"
I know this is an old post but wanted to add the solution that worked for me.
I attempted @Ipsnetwork Fix, to no avail.
The Fix:
conf t
crypto key generate rsa mod 2048 label <label_name>
ip ssh rsa keypair-name <label_name>
Can you send the output of the following commands:
sh ver | in image
sh ip ssh
(you can skip the RSA key hash area of the "sh ip ssh" output, since you shouldn't share that online.
@normanksmith  I had a bit different error but this solution fixed the issue.
This label technique fixed for us too.
Thanks Norman.
hi,
thanks for this! ran into the same problem.
the normal 'crypto key generate rsa modulus 2048' didn't work.
i was able to SSH again after using the 'label' and 'keypair-name' commands.
Thanks for sharing your experience.
Rick
