ports management
yasserTL
Hello
I'm hoping you can help.
I have two ports on the Cisco 2960 device: the first is the main port, and the second port is the backup. What I want to achieve is that when the main port goes down, the backup port will go up, and vice versa. I thought I could use Event Manager, but the 2960 doesn't support it. Is there any other solution you can suggest?
Thank you.
balaji.bandi
what IOS code running on the device ?
where is this 2 ports connected, what is the end device ?  can you do on the end device, if the IOS code not supported by EEM.
May be worth check flexlink - is that option for you ?
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_25_fx/configuration/guide/2960scg/swflink.pdf
BB
Check interface backup command
Is it available in this SW
MHM
