Prime Infra. 2.0 SSH and SNMP access to devices
rmeans
Level 3
Level 3
New Prime Infrastructure install. I am trying to discover my routers and switches.  From the Operate and Discovery section, I can "Quick Discovery".  I am given the option set the SNMP string.  After the discovery completes, I am add SSH credentials to each (individually) device.  Is there a method to set the SSH parameters ahead of time or via bulk?
Yes, go to OPERATE > DEVICE WORK CENTER
Just click in BULK IMPORT and choose your csv file
Excellent idea.  Thanks.
I suspect the "discovery settings" will allow SSH to be added but I haven't been able to make it work.  From the discovery settings section and after I enable SSH, I am asked to provide an IP address along with the username and password.  I get the username/password but I don't understand why an IP address is needed.
Either way, the bulk add is pretty easy.
Thanks again!
