Prime Infrastructure 1.2 Syslog
Carlos Morais
We are currently working on a solution comprising Cisco Prime Infrastructure 1.2 and we can't understand if Prime Infrastructure can work as a syslog collector, since we can't get it to show us any syslog messages sent from the network devices in its the Alarms & Events section. Is this a normal behavior? Is it necessary to use a remote syslog collector on another machine?
Best regards!
You can edit the file in vi if you're handy with that text editor. I find it much easier to just create a new file like aijaz described above (copied below here) using your favorite local text editor (I use notepad++ in Windows) and name it syslog_sev_filter.xml.
Once you have that, copy it onto the PI server using ftp. You can then drop into the shell rename the current file syslog_sev_filter.xml.old and then copy the new syslog_sev_filter.xml file from your ftp repository to the /opt/CSCOlumos/conf/ directory.
Follow all that with popping back up out of the shell and do "ncs stop" followed with "ncs start" to restart the server and you should now be getting all severity syslog messages in your application.
/opt/CSCOlumos/conf/syslog_sev_filter.xml file (Bold lines have been added here):
58 Replies 58
mmisonne
Level 2
Level 2
Hello
I have the same problem. ( with Prime 1.2) .
Is there any setup for this ?
Michel
According to this doc similar functionality is there, in the LMS and the NCS(PI) part.
http://www.cisco.com/en/US/partner/prod/collateral/netmgtsw/ps6504/ps6528/ps12239/app_note_c27-716230.html
Cheers,
Michel
Yes, in fact there is and it's working for us now. We've been able to solve the proble exposed above... it was only related to the logging level in the switch.
Best regards,
Carlos Morais
I tried user level 15 like below, and shut down an interface, but Prime can't receive any syslog
logging console informational
logging monitor informational
logging facility local0
logging source-interface Vlan1
logging 192.168.7.77
SW2(config-if)#
username cisco privilege 15 password 0 cisco
username test password 0 cisco
This is what I understand...
Prime has syslog built-in service.  If I go to events, I can see some informational, critical, error message from events panel, however syslogs panel doesn't show up any thing even if switch generates syslog.
Do you have any idea?
I guess it is good that you don't receive any messages. Try to change the following command:
logging facility local0 to logging facility local7
Best regards.
I found answer.  Anyway thanks.
Currently PI 1.2 does not have full syslog reporting capability. That is an enhancement scheduled for a future release of NCS, under the enhancement bug CSCud66666.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCud66666
Found same bug using PI version 1.2 (1.2.1.012).
PI shows only some syslog messages from ASA for a period of time, but nothing else. And now I got no further syslog messages from ASA anymore, while I changed nothing on PI and ASA.
Hi Kyujin,
How about PI 1.3, did it support for syslog collection??
Jerri
My Syslog Server on Cisci PI 1.3 is not working.
Someone please give me the advise.
As noted above, PI does not have full syslog server reportng capabilities. That applies to both PI 1.2 and 1.3.
mmisonne
Level 2
Level 2
Prime 2.0 , (available now) is integrating a real syslog server.
I hope Prime 2.0 will work better with all services which were integrated. I am not happy with the entire Prime (only using version 1.2.1.012) at this time.
we are using Prime 2.0 now, but the syslog problem remains. It seems that cisco did more bug fixing (which was definitely necessary) than implementing new functions to PI 2.0.
If I understand the More Info section in this bug description
https://tools.cisco.com/bugsearch/bug/CSCud66666
correctly, then we have to wait für PI 2.1 for a working syslog server.
Syslog is working on PI2.0. by default Prime only accepts the severity 0 and 1. you will need to modify a file in PI 2.0 to allow prime to accept Syslog messages.
change following file
Aijaz
Please rate helpful posts...
