Bookmark
Subscribe
1481
Prime Infrastructure 1.3 , Device Unreachable
aslamta123
We are facing issues with adding switches in PI 1.3. Bulk update of switches is not functionaning properly so we added switches one by one...
But still showing many switches are unreachable..  SNMP v3 confoguration and credentials are fine. It was reachable for sometime and collected the details but after sometime the devcies became unreachable...
Any idea about the Bulk update and the above unreachable   issues...  Attached the screenshot of the Device status page..
Rgds
Aslam
Richard Atkin
Level 4
Level 4
This sounds very similar to a known bug; try using SNMP v1 instead.
Thansk for the reply Richerd, Could you please share the Big ID if you have...
