Prime infrastructure 2.0 inventory reports
trimmy
In lms it was easy to get inventory report on our router cards draughtboards etc. when I go to report launch pad>device>detailed hardware and run combined inventory I get "no data found" under the modules and interfaces....this is the ONLY report requested by the customer, is this really not available in PI 2.0?
AFROJ AHMAD
Reports  (deatiled Hardware ) are working fine  for me.  check the attached screenshot
Check the device  "Inventory collection status " under device >workcenter   . status should be completed for those device
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thanks afroz at least this shows me it can be done....my reports say zero data for the card modules interfaces. I have updated prime to highest device pack still no joy?
I also have this problem with the latest version of Cisco Prime 3.1.6 and all the patches, I need a list of all modules including Serial numbers associated with the detailed hardware inventory.  This does not work please see attachment is there any reason for this? Please ignore this I have found the solution.
