Prime Infrastructure 3.0 - Cannot create WLAN/Wifi Guest Users
oliver.scheer
I want Prime Infrastructure 3.0 to manage the WLAN/Wifi guest users on a 5508 Wireless Controller.
But i always got an error when adding a new user.
Error(s): You must correct the following error(s) before proceeding:
Error:Could not apply this guest user account as it may already exist on the controller(s). Please verify if controller(s) is reachable from PI and the selected profile exists on the controller(s) with Webauth enabled on it. Please send PI logs to the network administrator.
The Device Credential Verification shows the following:
IP Address / Host Name
Reachability
SNMP
Read
Write
CLI
Login
Enable
HTTP/HTTPS
HTTP/HTTPS Status
Profile Name
Last Updated At
10.240.2.14
Reachable
snmpv2c
Success
Failure
ssh2
Success
Success
Not Verified
Not Verified
2016-Sep-09, 08:35:09 MESZ
I already readded the controller, set a new snmp write community and restarted Prime.
Any idea?
7 Replies 7
AFROJ AHMAD
Hi Oliver,
from the screen shot , I see "SNMP WRITE" is failure.  it has to be successful to get this work.
Please ensure above . once you take care of it and still see the issue and you can follow the below actions and see if they help::
1. Adjusted the get and set  PDU values to 20.
Stop the Prime Infrastructure, choose Administration > Settings > System Settings > Network and Device > SNMP, and edit the Maximum VarBinds per Get PDU and Maximum VarBinds per Set PDU values to 20
2. Check the License ,hope there is no licensing issue
3.Try  removing and re-adding the controller.
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
I changed the values to 20
Then I re-added the controller
But same problem:
Cisco Prime
Generated: 2016-Sep-12, 11:58:55 MESZ
Infrastructure
Report Type: ImmediateReport
Reachability
SNMP
Read
Write
CLI
Login
Enable
HTTP/HTTPS
HTTP/HTTPS Status
Profile Name
Last Updated At
10.240.2.14
Reachable
snmpv2c
Success
Failure
ssh2
Success
Success
Not Verified
Not Verified
2016-Sep-12, 11:44:00 MESZ
License is okay:
Licenses
Type Licensed
Lifecycle
213 of 225 devices used
Controller Count 1
AP Limit 200
Type Permanent
what is the community string you have configured ?
Read only or read write ?
Thanks-
Afroz
i have a read-only and a read-write community string
try removing the read community ,leaving the RW and see how it works
Thats not possible.
Error Message: Read Community String is Required.
cihanogeturk
Did you actually create a new SNMP crendentials (or modified existing ones) on controller(s) itself?
If you have read only credential configured on controller, you will not be able to create any guest user.
