10-12-2015 02:09 AM
Hi there,
Upgraded our Prime Infrastructure from 2.2 to 3.0 and every day we have to restore from a snap we did after the upgrade. The Disk seems to have filled up. The message we get on the V Centre is
And the resources look full but cant get in to have a poke around to see what's causing it. Anyway of getting it to boot in a way so we can get in to see what the issue is or is it a TAC case?
When we get the Snap image up and running we do a ncs stop; ncs clean; ncs start which leaves us like this disk wise
Directory of disk:/
20 Oct 06 2015 20:56:58 crash
4096 Oct 09 2015 12:50:54 defaultRepo/
4096 Mar 06 2015 22:21:06 ftp/
16384 Dec 11 2014 23:46:41 lost+found/
4096 Oct 09 2015 12:51:04 sftp/
4096 Mar 05 2015 13:27:19 ssh/
4096 Mar 05 2015 13:27:19 telnet/
81920 Oct 09 2015 22:01:18 tftp/
Usage for disk: filesystem
197230592 bytes total used
131897712640 bytes free
139279441920 bytes available
Should I be looking to add some more disk?
10-12-2015 04:58 AM
hey
when you ssh to the pi try (if you have noot used root before you need to use root_enable and make a password)
root
df -h
then you get a nice view of how disk space is on your pi
10-12-2015 05:18 AM
Hi David,
It all looks pretty ok to me. Not sure what could be filling it up. I have it backed up every week to an FTP server so its not like its storing backup jobs on it.
ade # df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/smosvg-rootvol
3.8G 473M 3.2G 13% /
/dev/mapper/smosvg-varvol
3.8G 643M 3.0G 18% /var
/dev/mapper/smosvg-optvol
694G 151G 508G 23% /opt
/dev/mapper/smosvg-tmpvol
1.9G 36M 1.8G 2% /tmp
/dev/mapper/smosvg-usrvol
6.6G 1.3G 5.1G 21% /usr
/dev/mapper/smosvg-recvol
93M 5.6M 83M 7% /recovery
/dev/mapper/smosvg-home
93M 5.6M 83M 7% /home
/dev/mapper/smosvg-storeddatavol
9.5G 151M 8.9G 2% /storeddata
/dev/mapper/smosvg-altrootvol
93M 5.6M 83M 7% /altroot
/dev/mapper/smosvg-localdiskvol
130G 15G 109G 12% /localdisk
/dev/sda2 97M 5.6M 87M 7% /storedconfig
/dev/sda1 485M 25M 435M 6% /boot
tmpfs 7.8G 2.5G 5.4G 32% /dev/shm
10-13-2015 03:11 PM
Hey Graham,
Run into something like this before. Once the /opt directory went nuts, TAC called it a database error had to rebuild/restore from backup. Check during the day to see if the used space rises dramatically.
Another time the VM volume was full. VM assigns the disk space but does not actually fence it off. The volume was close to full and when Prime went to write more data V center threw an error.
10-19-2015 06:22 AM
Check for any created snapshots on the VM itself and delete them, this will free up disk space
