Bookmark
Subscribe
1486
Prime infrastructure 3.7, conditional change of network interface
Harrie Hendriks
For network access we used dot1x for authentication. Now we need to change all the dot1x access interfaces, but not the static access interfaces.
Is in prime infrastructure 3.7 a configuration method where I can setup the next configuration
IF "dot1x pae authenticator" AND "mab" THEN
 ADD "authentication order mab dot1x"
 ADD "authentication priority dot1x mab"
Part of interface Config before
mab
Part of interface Config after
mab
Best Regards,
Harrie
0 Replies 0
