Prime Infrastructure 3.7 Deployment
Learnercisco
Hi Tech Guys,
I have configured Prime infrastructure High Availability in LOCAL MODE (two separate physical server with Virtual IP address).
My question is , when i shutdown the primary instance, the Prime infrastructure GUI should be accessible through Virtual IP and Standby IP Instance IP  or no ?
I m facing the following :
I am using the Virtual IP for SNMP TRAP. My problem is when i shutdown primary instance i am unable to reach to Virtual IP Address and GUI access to the Prime Infrastructure.
Please let me know if somebody experience the same.
0 Replies 0
