Prime Infrastructure Licensing
MUHAMMAD_ALIM
Frequent Visitor
Frequent Visitor
Hello, I purchased license prime infrastructure ver. 1 a year ago and never use it. Now i have prime infrastructure ver.2,
My Question is : Can I use license prime infrastructure ver.1 to my new prime infrastructure ver.2 ?
Leo Laohoo
Leo Laohoo
Yes.
Do i need to upgrade or update it first or just put the license in ?
None.
Start from scratch.  If you upgrade from version 1 to 2.1, you need to do a lot of "hops".  It is a lot easier (and faster) to just start from scratch and install 2.1 into your VM.
Once you're done, put the license in.
Thank you, gonna try it
