Prime Infrastructure upgrade
dpcdpcdpc
Hello guys,
We have Cisco Prime 3.3 as our wireless network manager and I would like to update it to it's last version (3.9). Since I've never done it before I was wondering if I need to do an upgrade in-between and then go to 3.9. (For example if I first need to go to 3.5 and finally 3.9).
If this was the case, what would you recommend? A fresh install and then upload my AP database?
Thanks in advance!
balaji.bandi
Read the Upgrade notes and requirements.  ( i suggest each upgrade test and take the backup of that version and upgrade to the next version, do not upgrade to all versions without checking) - this required some planning, ( i know Prime is not going to be in Datapath in the network to interrupt) but you miss management while the upgrade takes place.
you need to upgrade path 3.3 --> 3.4 --3.7 --> 3.9
How to Upgrade From Previous Releases of Prime Infrastructure
If your existing Prime Infrastructure is 3.7.x or 3.8.x, and your upgrade path contains 3.4.x or earlier versions, then you cannot in-line upgrade that server to Prime Infrastructure 3.9 due to security vulnerabilities in the underlying Red Hat 6 installation. You will need to take a backup of the Prime Infrastructure 3.7.x or 3.8.x server, deploy a fresh Prime Infrastructure 3.9 server, and restore that backup into the Prime Infrastructure 3.9 server.
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-9/quickstart/guide/bk_Cisco_Prime_Infrastructure_3_9_0_Quick_Start_Guide.html#task_1070867
BB
balaji.bandi
BB
marce1000
 - Ref : https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-9/release/notes/bk_Cisco_Prime_Infrastructure_3_9_0_Release_Notes.html
 M.
Leo Laohoo
Export the maps and database and do a fresh install.
Do not forget to read the Release Notes (of PI 3.9) before importing the maps and DB.
