05-24-2021 07:23 AM
I have a Cisco 350sg 28p switch. I'm using it to connect the Shure MXA910.On my managed switch I have two VLANs. VLAN 1 and VLAN 2.
The Shure mic only have one port but two different I.P address one for the control and the other for the dante. It's plugged in to the port 13 of the switch. Inside the switch it shows that the control and dante are sharing the port 13 (two I.P addresses one Port) VLAN 1.
This there a way to separate them in the switch? Control on VLAN 1 and dante to VLAN 2.
Solved! Go to Solution.
05-24-2021 07:37 AM
what happend if you make the Trunk port- vlan1 is default native vlan.
05-24-2021 07:37 AM
