Problem importing c7600s72033-advipservicesk9-mz.152-4.S1.bin in Ciscoworks RME
Rolando Bega
Hi all,
we have problem importing IOS (details are in the subject) in LMS 4.0.1. The error we obtain is: "SWM0009: Could not extract image attributes. Check whether it is supported by Software Management". The MD5 of my local file is the same of the one reported by Cisco site (http://www.cisco.com/cisco/software/release.html?mdfid=282201754&softwareid=280805680&release=15.2.4S&flowid=843).
No helps reading https://supportforums.cisco.com/message/639266.
Any suggestions?
Thanks in advance.
5 Replies 5
Please check the tag it may be helpful to you..
Problems importing c2960-lanbasek9-tar.122-35.SE.tar into CW RME
Plese rate helpful tags
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
Thank you.
Regards.
Rolando
Vinod Arya
If it is an option, try cisco.com option and try to add it to repository.
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Unfortunately is not an option.
Thank you.
Rolando
If the image is already running on one of the device, try importing it. Just to make sure no issues with the image.
As you are trying to copy it from the local file system, try to give file a permission rw to all users. A new download from cisco.com is recommended with correct MD5 value and try to add it to repository again.
