Problem with console connection
alliasneo1
Level 3
Level 3
Hi, I currently have a problem with my console cable connection to switches.
I've tried different switches and different cables and different software and it does the same on all of them.
I'm using MobaTerm and Putty and I connect up fine but then when I type something like conf t, I'll get half way through typing and then it hangs and then types lots of characters like this:
connnnnnnnnnnnnnnffffff t
The settings are:
8 Data Bits
1 Stop Bits
None Parity
None Flow Control
The same thing happens when pressing enter as well, it will suddently hit enter lots of times:
Switch(config)#
Switch(config)#
Switch(config)#
Switch(config)#
Switch(config)#
Switch(config)#
Switch(config)#
Switch(config)#
Switch(config)#
Switch(config)#
Switch(config)#
Switch(config)#
Switch(config)#
Switch(config)#
Switch(config)#
Switch(config)#
Switch(config)#
Switch(config)#
5 Replies 5
balaji.bandi
what is this device model ? never seen this issue before :
what baud rate ?
i use putty all time not got that issue.
show run  (post here)
BB
Georg Pauwen
if this happens on all switches, the issue is likely with the device you are initiating the connection from. What do you use, a laptop, PC ?
I use a laptop and it's fine on that but when I'm docked at my desk my external keyboard seems to do it. Drivers for the keyboard maybe?
this is error on your keyboard driver or keyboard. check with different PC/Laptop. if the issue is solved, try updating your keyboard drivers/OS, etc.
Good luck
KB
Hi, thanks for the reply. I use a laptop and it's fine on that but when I'm docked at my desk my external keyboard seems to do it. Drivers for the keyboard then?
