Problem with EssentialsDM
mladenp
Level 3
Level 3
I (my customer) have similar problem like described in this discussion:
https://supportforums.cisco.com/message/669826#669826
EssentialsDM is stuck in "waiting to initalise" state. Problem started to occurring around a last thursday.
EssentialsDM.log, EssentialsDM_Server.log and pdshow attached.
Mladen
It appears you have the Windows remote management service started which listens on tcp/47001.  This port is required by EssentialsDM.  Can you disable Windows RM, and see if that helps?
6 Replies 6
Joe Clarke
Do you have QPM installed on this server?
No, we haven't.
Shutdown Daemon Manager, then port the output of the command "netstat -a -n -o -b".
here is output.
Yes, it helps. Everything is OK again.
Thank you very much,
Mladen
