problem with firmware upgrade isr4221
aragorn43
I am a support IT, no cisco knowledge at all. I have a router 4221 that needed to get the firmware downgraded. There is a problem with the router, it had the the version
Cisco IOS XE Software, Version 16.12.03, it was done the downgrade but not correctly and it sends this
unable to open flash:isr4200-universalk9_ias.16.04.02.SPA.bin (14)
autoboot: boot failed, restarting...
Resetting .......
if I do "command Break" it goes to Rommon, It does not takes "enable",
rommon 1 > en
monitor: command "en" not found
I can boot with a usb with the file
boot usb0:isr4200-universalk9_ias.16.04.02.SPA.bin
an I already copied it to bootflash, but when I do
boot system flash:isr4200-universalk9_ias.16.04.02.SPA.bin
or
verify flash:isr4200-universalk9_ias.16.04.02.SPA.bin
it sends
*May 17 18:05:27.920: %Error opening bootflash:isr4200-universalk9_ias.16.04.02.SPA.bin (No such file or directory)
*May 17 18:05:27.920: %SIGNATURE-3-NOT_ABLE_TO_PROCESS: %ERROR: Not able to process Signature in bootflash:isr4200-universalk9_ias.16.04.02.SPA.bin.
when I do dir I see the files and folder but I do not see the version 16.04.02,
Directory of bootflash:/
11 drwx 16384 Jul 30 2021 18:58:19 +00:00 lost+found
80641 drwx 4096 May 17 2023 18:02:07 +00:00 .prst_sync
12 -rw- 7905 Jul 30 2021 19:24:51 +00:00 prev_packages.conf
23 -rw- 429194512 May 17 2023 18:05:05 +00:00 y
16 -rwx 26 Jul 30 2021 19:18:12 +00:00 .installer
306433 drwx 4096 Jul 30 2021 19:17:05 +00:00 .ssh
161281 drwx 4096 Jul 30 2021 19:19:11 +00:00 core
88705 drwx 4096 Jul 30 2021 19:17:18 +00:00 .rollback_timer
13 -rw- 132108 May 17 2023 16:44:34 +00:00 memleak.tcl
14 -rw- 20109 Jul 30 2021 19:17:35 +00:00 ios_core.p7b
387073 drwx 4096 Jul 30 2021 19:17:41 +00:00 virtual-instance
354817 drwx 4096 Jul 30 2021 19:24:51 +00:00 .dbpersist
201601 drwx 4096 Apr 27 2023 15:50:33 +00:00 sdwan
15 -rw- 419430400 May 17 2023 16:45:26 +00:00 .sdwaninstallerfs
225793 drwx 24576 May 17 2023 18:07:22 +00:00 tracelogs
72577 drwx 4096 May 17 2023 16:43:39 +00:00 .sdwaninstaller
96769 drwx 4096 Jul 30 2021 19:18:13 +00:00 vmanage-admin
346753 drwx 4096 Jul 30 2021 19:18:15 +00:00 callhome
17 -rw- 30 May 17 2023 18:02:10 +00:00 throughput_monitor_params
112897 drwx 4096 Jul 30 2021 19:19:03 +00:00 onep
193537 drwx 4096 May 17 2023 16:45:55 +00:00 license_evlog
314497 drwx 4096 Jul 30 2021 19:20:19 +00:00 .cdb_backup
18 -rw- 35 Mar 23 2023 15:52:45 +00:00 pnp-tech-time
19 -rw- 160488 Mar 23 2023 15:52:51 +00:00 pnp-tech-discovery-summary
20 -rw- 279 May 17 2023 17:35:43 +00:00 btdecode_err
233858 -rw- 3 Jul 30 2021 19:21:31 +00:00 hugepage.conf
233860 -rw- 50224 Jul 30 2021 19:21:31 +00:00 isr4200-firmware_dreamliner.16.12.03.SPA.pkg
233861 -rw- 11199536 Jul 30 2021 19:21:31 +00:00 isr4200-firmware_ngwic_t1e1.16.12.03.SPA.pkg
233862 -rw- 9274416 Jul 30 2021 19:21:31 +00:00 isr4200-firmware_nim_async.16.12.03.SPA.pkg
233863 -rw- 4613172 Jul 30 2021 19:21:31 +00:00 isr4200-firmware_nim_bri_st_fw.16.12.03.SPA.pkg
233864 -rw- 17630256 Jul 30 2021 19:21:31 +00:00 isr4200-firmware_nim_cwan.16.12.03.SPA.pkg
233865 -rw- 2647084 Jul 30 2021 19:21:32 +00:00 isr4200-firmware_nim_ge.16.12.03.SPA.pkg
233866 -rw- 11510832 Jul 30 2021 19:21:32 +00:00 isr4200-firmware_nim_shdsl.16.12.03.SPA.pkg
233867 -rw- 6321200 Jul 30 2021 19:21:32 +00:00 isr4200-firmware_nim_xdsl.16.12.03.SPA.pkg
233868 -rw- 10163244 Jul 30 2021 19:21:32 +00:00 isr4200-firmware_prince.16.12.03.SPA.pkg
233869 -rw- 399742008 Jul 30 2021 19:21:43 +00:00 isr4200-mono-ucmk9.16.12.03.SPA.pkg
233870 -rw- 33227862 Jul 30 2021 19:23:06 +00:00 isr4200-rpboot.16.12.03.SPA.pkg
233859 -rw- 7905 Jul 30 2021 19:26:02 +00:00 packages.conf
21 -rw- 1154 Mar 16 2023 21:05:48 +00:00
22 -rw- 4886 May 17 2023 17:21:15 +00:00 start
and if I copied it again, it says that is already there.
I am sorry to ask something that maybe its simple but I do not have the knowledge and the network guys are not helping, so I am trying to figure it out. I have search and there are a lot of hits on how to do the firmware upgrade, but not with this kind of error.
I will really appreciate any feedback, either direct or pointing me in the right direction to find the fix, if there is one.
Thank you very much
Mark Elsen
   >...%Error opening bootflash:isr4200-universalk9_ias.16.04.02.SPA.bin (No such file or directory)
                     - Verify if the copy to the bootflash was successful ,
 M.
Hello, Good morning. Thanks. Yes I just copied it again from the USB. I got this
Router#copy usb0:isr4200-universalk9_ias.16.04.02.SPA.bin bootflash:/
Destination filename [isr4200-universalk9_ias.16.04.02.SPA.bin]? y
%Warning:There is a file already existing with this name
Do you want to over write? [confirm]y
Copy in progress...CCCCCCCCCCCCCCCC... (and a lot of this) and at the end, this
429194512 bytes copied in 32.162 secs (13344771 bytes/sec)
But when I do dir I still don't see it
80641 drwx 4096 May 18 2023 15:35:49 +00:00 .prst_sync
23 -rw- 429194512 May 18 2023 15:49:59 +00:00 y
13 -rw- 132108 May 17 2023 18:52:29 +00:00 memleak.tcl
15 -rw- 419430400 May 17 2023 18:53:21 +00:00 .sdwaninstallerfs
225793 drwx 32768 May 18 2023 15:51:02 +00:00 tracelogs
72577 drwx 4096 May 17 2023 18:51:34 +00:00 .sdwaninstaller
17 -rw- 30 May 18 2023 15:45:50 +00:00 throughput_monitor_params
193537 drwx 4096 May 17 2023 18:17:38 +00:00 license_evlog
22 -rw- 4886 May 17 2023 17:21:15 +00:00 startup
7194652672 bytes total (5454819328 bytes free)
When I do
Router#verify bootflash:isr4200-universalk9_ias.16.04.02.SPA.bin
%ERROR: Unable to process embedded hash in bootflash:isr4200-universalk9_ias.16.04.02.SPA.bin.
Router#
*May 18 15:54:50.621: %Error opening bootflash:isr4200-universalk9_ias.16.04.02.SPA.bin (No such file or directory)
*May 18 15:54:50.621: %SIGNATURE-3-NOT_ABLE_TO_PROCESS: %ERROR: Not able to process Signature in bootflash:isr4200-universalk9_ias.16.04.02.SPA.bin.
The firmware file is there.  In the bootflash.  You renamed the firmware to the filename "y".
Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode)
