Problem with my dns on my dhcp config
Drakestes
I hsd configure a dhcp with my dns server on my ASA firewall, It was working fine, but suddently, my dhcp client dosent receive my dns config at all, it show 0.0.0.0 insted of 10.0.1.50 that I have set.
I tried to change the dns server in my config but it does not replicate on my client.
I was wondering what I did wrong and how to fix it?
Thanks in advance! :)
My asa actual config are the following:
ASA Version 9.6(1)
hostname Firewall
domain-name climoilou.ca
names
interface GigabitEthernet1/1
nameif Outside
security-level 0
ip address 10.0.0.2 255.255.255.0
interface GigabitEthernet1/2
nameif DNS
security-level 100
ip address 10.0.1.1 255.255.255.0
interface GigabitEthernet1/3
nameif Web
security-level 100
ip address 10.0.2.1 255.255.255.0
interface GigabitEthernet1/4
nameif Lab1
security-level 100
ip address 10.0.3.1 255.255.255.0
interface GigabitEthernet1/5
nameif Lab2
security-level 100
ip address 10.0.4.1 255.255.255.0
interface GigabitEthernet1/6
nameif Lab3
security-level 100
ip address 10.0.5.1 255.255.255.0
interface GigabitEthernet1/7
nameif Lab4
security-level 100
ip address 10.0.6.1 255.255.255.0
interface GigabitEthernet1/8
no nameif
no security-level
no ip address
shutdown
interface Management1/1
management-only
no nameif
no security-level
no ip address
object network inside-net
subnet 10.0.1.0 255.255.255.0
route Outside 0.0.0.0 0.0.0.0 10.0.0.1 1
access-list group extended permit tcp any any eq domain
access-list group extended permit tcp any any eq www
access-list group extended permit tcp any any eq smtp
access-list group extended permit tcp any eq domain any
access-list group extended permit udp any eq domain any
access-list group extended permit udp any any eq domain
access-list group extended permit icmp any any echo
access-list group extended permit icmp any any echo-reply
access-list group extended permit tcp any any eq pop3
access-group group in interface Outside
aaa authentication ssh console LOCAL
username admin password 4IncP7vTjpaba2aF encrypted
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect http
inspect icmp
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global-policy
service-policy global_policy global
telnet timeout 5
ssh 10.0.1.0 255.255.255.0 DNS
ssh 203.1.2.0 255.255.255.0 Outside
ssh timeout 10
dhcpd dns 10.0.1.50
dhcpd address 10.0.3.100-10.0.3.131 Lab1
dhcpd enable Lab1
dhcpd address 10.0.4.100-10.0.4.131 Lab2
dhcpd enable Lab2
dhcpd address 10.0.5.100-10.0.5.131 Lab3
dhcpd enable Lab3
dhcpd address 10.0.6.100-10.0.6.131 Lab4
dhcpd enable Lab4
I have set my dns server on each interface instead of a general DHCP rule and it wolved my problem, but thanks alot for your help! :)
johnd2310
Level 8
Level 8
Run wireshark on the client to confirm that the ASA firewall is not sending that option. You could also trying setting the option per pool.
John
**Please rate posts you find helpful**
