03-07-2005 12:26 AM
Hai,
I am Using LMS2.2 and ciscoview 5.5.
I am having the following problems in viewing my devices in cisco view.
1.while viewing PIX 525 it is showing the box with only 2 interfaces (inside and outside) but i am having the add on card with 4 interfaces where 3 are connceted to 3 different zones.
Also i am having the Failover connceted but the failover connceted port is showing it is not showing any indication that failover is connected(Link shows green color something) Is there is any options like that?
2. While viewing my Router 7200 it is showing front and rear view where in rear view i can able to see Both primary and redundant pwer supply LEDs green.
But as in the case of my RAS 5350 it is not showing the power LED as green(I can able to see the power LEDS)
3. In my Topology services my PIX 525 and 515 , IDS 4215 and Cisco ACS 3.2 are not shown. Is there any specific update for this to be displayed?
Kindly clarify the above issues .
I am thankful to you.
03-07-2005 11:16 AM
Have you installed the latest IDU and CV device packages from CCO first?
03-07-2005 11:01 PM
Yes i Installed CM3.3 IDU 11.0 and RME3.5 IDU 11.0
I am having CWCS sp2 - 2.2
CM - 3.3
DFM - 1.2
RME - 3.5
Any thing to be added??
Thanks for the reply
