Problems verifying image on flash
josephjmg
Visitor
CCOB-4F-2960X#dir
Directory of flash:/
*SNIP*
6 -rwx 16800768 Apr 25 2019 10:04:25 -04:00 c2960s-universalk9-mz.152-2.E9.bin
122185728 bytes total (83666944 bytes free)
CCOB-4F-2960X#verify flash:c2960s-universalk9-mz.152-2.E9.bin
File system hash verification failed for file flash:/c2960s-universalk9-mz.152-2.E9.bin(No such file or directory).
WTF??
And yes, I've tried flash:/, flash1:/, flash2:/ etc...tried every combination but it won't work. I've never had any problems verifying an image before, so I don't understand.
Jaderson Pessoa
@josephjmg hello,
try in bold exemple below;
CCOB-4F-2960X#verify /md5 flash:c2960s-universalk9-mz.152-2.E9.bin
WTF??
If you dont need input /md5, run commands below and try again without /md5
SW# configure terminal
SW(CONFIG)# file verify auto
Check it for more information: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sys-image-mgmt/configuration/15-s/sysimgmgmt-15-s-book/sysimgmgmt-md5.html
Jaderson Pessoa
*** Rate All Helpful Responses ***
Jaderson Pessoa
@josephjmg hello,
WTF??
Jaderson Pessoa
The /md5 part worked, sorry to have wasted your time with such a simple thing. Thank you for your help!
you're welcome
Jaderson Pessoa
yaqoobkk
I faced the same issue while upgrading IOS version from E5 to E8:
Loading c2960x-universalk9-mz.152-7.E8.bin from 10.1.1.1 (via Vlan1): !!!!!!!!O!OO!OO!O!OO!OOO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OOO!OO!OO!OO!O!OO!OOOO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OOO!OO!OO!OO!OO!O!OO!OOO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OO!OOO!OO!OO!O
[OK - 26785792 bytes]
2 drwx 512 Mar 12 2002 06:06:33 +03:00 c2960x-universalk9-mz.152-7.E5
494 -rwx 110 Mar 12 2002 06:24:06 +03:00 info
495 drwx 512 Mar 12 2002 06:30:25 +03:00 pnp-info
496 -rwx 23836 May 24 2023 10:16:23 +03:00 config.text
497 drwx 512 Sep 23 2000 13:42:08 +03:00 pnp-tech
500 drwx 1024 Jan 26 2009 08:07:27 +03:00 crashinfo_ext
511 -rwx 52 Jul 25 2000 10:45:33 +03:00 express_setup.debug
512 -rwx 796 May 24 2023 10:23:48 +03:00 vlan.dat
513 -rwx 26785792 May 24 2023 10:54:04 +03:00 c2960x-universalk9-mz.152-7.E8.bin
518 -rwx 3096 May 24 2023 10:23:57 +03:00 multiple-fs
514 -rwx 20144 May 9 2023 06:57:42 +03:00 config.text.backup
515 -rwx 5638 May 9 2023 06:57:44 +03:00 private-config.text.backup
517 -rwx 5638 May 24 2023 10:16:23 +03:00 private-config.text
(config)#boot system switch 2 c2960x-universalk9-mz.152-7.E8.bin
Verifying file integrity of flash:c2960x-universalk9-mz.152-7.E8.bin
File system hash verification failed for file flash:c2960x-universalk9-mz.152-7.E8.bin(No such file or directory).
Loading "c2960x-universalk9-mz.152-7.E8.bin"...c2960x-universalk9-mz.152-7.E8.bin: no such device
Error loading "c2960x-universalk9-mz.152-7.E8.bin"
