09-05-2011 07:03 PM
I am trying to monitor routers Cisco 2610, 2801 and 1760 with a monitoring software called zenoss. and I cant see on this devices the powersupply state, temperature sensor, fan state, i dont know if this models of routers cant support the monitoring of this component on the devices.
anybody know what can i do to monitoring this component? what kind of Oid I can use to get this components state?
09-06-2011 08:45 AM
I suspect that these devices do not report detailed values.
A tip that may help is to do a "show env all" at the CLI. From a device that does not have detaild values you will get something like this:
#sh env all
FAN is OK
Internal POWER supply is OK
RPS is NOT present
From a device that does have detailed values you will get something like this:
1#sh env all
FAN is OK
TEMPERATURE is OK
Temperature Value: 41 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 58 Degree Celsius
Red Threshold : 68 Degree Celsius
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1 Built-in Good
SW Status RPS Name RPS Serial# RPS Port#
1 Not Present <>
Hopr this helps.
Mark.
Montitored by PRTG <http://http://www.paessler.com/>
09-06-2011 02:28 PM
Hi Mark,
Kindoy try to do snmpwalk from the NMS tool for the OID
1.3.6.1.4.1.9.9.13
I tried this in my lab and its working fine :-
nms-server#sh env all FAN is OK TEMPERATURE is OK Temperature Value: 35 Degree Celsius Temperature State: GREEN Yellow Threshold : 58 Degree Celsius Red Threshold : 68 Degree Celsius SW PID Serial# Status Sys Pwr PoE Pwr Watts -- ------------------ ---------- --------------- ------- ------- ----- 2 Built-in Good SW Status RPS Name RPS Serial# RPS Port# -- ------------- ---------------- ----------- --------- 2 Not Present <> nms-server# C:\usr\bin>snmpwalk.exe -v 2c -c gagan 10.78.136.41 1.3.6.1.4.1.9.9.13 SNMPv2-SMI::enterprises.9.9.13.1.1.0 = INTEGER: 13 SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.2005 = STRING: "SW#2, Sensor#1, GREEN " SNMPv2-SMI::enterprises.9.9.13.1.3.1.3.2005 = Gauge32: 36 SNMPv2-SMI::enterprises.9.9.13.1.3.1.4.2005 = INTEGER: 68 SNMPv2-SMI::enterprises.9.9.13.1.3.1.5.2005 = INTEGER: 0 SNMPv2-SMI::enterprises.9.9.13.1.3.1.6.2005 = INTEGER: 1 SNMPv2-SMI::enterprises.9.9.13.1.4.1.2.2004 = STRING: "Switch#2, Fan#1" SNMPv2-SMI::enterprises.9.9.13.1.4.1.3.2004 = INTEGER: 1 SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.2003 = STRING: "Sw2, PS1 Normal, RPS NotE xist" SNMPv2-SMI::enterprises.9.9.13.1.5.1.3.2003 = INTEGER: 1 SNMPv2-SMI::enterprises.9.9.13.1.5.1.4.2003 = INTEGER: 2 SNMPv2-SMI::enterprises.9.9.13.2.1.0 = INTEGER: 2 SNMPv2-SMI::enterprises.9.9.13.2.3.0 = INTEGER: 2 SNMPv2-SMI::enterprises.9.9.13.2.4.0 = INTEGER: 2 SNMPv2-SMI::enterprises.9.9.13.2.5.0 = INTEGER: 2 SNMPv2-SMI::enterprises.9.9.13.2.6.0 = INTEGER: 2
Many Thanks,
Gaganjeet
09-06-2011 03:19 PM
thanks for your help Gaganjeet Chugh and Mark.
but I would like to know on which especific device model you proved sh env all. and what is IOS version of that devices?
09-06-2011 11:11 PM
Hi Ronald,
I tried this in our lab on image 12.2(53)SE.
More about the OID :-
Object | ciscoEnvMonMIB |
OID | 1.3.6.1.4.1.9.9.13 |
MIB | CISCO-ENVMON-MIB ; - View Supporting Images ![]() |
Description | "The MIB module to describe the status of the Environmental Monitor on those devices which support one. |
You can view this link and click on the supporting images to check your device ios version.
Many Thanks,
Gaganjeet
