11-18-2011 12:27 AM
Hello gurus,
I have the following question:
when I try to distribute an IOS image to a 2960 switch via RME Software Distribution I get the following error message:
Software Distribution Message: SWIM1100: Cannot find SNMP-V2 Read-Write Community String in the Device and Credential Repository.
Do I need to have set up SNMP write community for that operation even if I want to use SSH for Software Image upgrade?
The system used is LMS 3.2/RME 4.3.1
Thanks in advance for all your input,
Vesko
11-18-2011 12:32 AM
The error message is (too) generic.
You need to tell SWIM to use SSH or it will use telnet.
Check the joblogs in \CSCOpx\files\rme\jobs\swim\
Cheers,
Michel
11-18-2011 12:39 AM
Hello Michel,
thanks for the fast answer.
At the moment the settings in the Software Management Preferences are:
Image Transfer Protocol Order:
SCP, TFTP
and
Use SSH for Software Image upgrade and software image through CLI enabled.
Is that what you meant that needed to be done? If yes,even though I have set that up I still get that error message.
Vesko
11-18-2011 12:57 AM
Yes that is what I meant. The message you get is meaningless generic.
You may want to post the joblogs here.
You may need to rerun the job with debug on swim enabled.
Did you configure a SCP username and password?
Cheers,
Michel
11-18-2011 01:20 AM
Hi again,
I will check out these logs now and if I cannot find my way there I will ask for help.
Vesko
