Puts seems to output blank
s.louw
Consider the applets below.
One assigns a variable and one sends it to the CLI output.
The CLI output is bank.
Why is this?
event manager environment Var_3G_Unshut
event manager applet App_Set_Var_3G_Unshut
 event none
 action 2.0 set Var_3G_Unshut 1
event manager applet App_View_Var_3G_Unshut_CLI
 event none
 action 1.0 puts "Var_3G_Unshut is $Var_3G_Unshut"
The output is blank as mentioned:
c617rt19#event manager run App_View_Var_3G_Unshut_CLI
Var_3G_Unshut is
I know from running an alterntive script with an if statement in it that the variable is greeter then 0 (Applet left off for clarity can post if requested)
Joe Clarke
Just because you set the value of an environment variable in a policy does not mean it will be set globally.  Environment variables are read-only.  If you want to set the value, you need to enter config mode and reconfigure it.
