Q: Best Method for TCL scripts to pass info between routers?
tproeber
I want to have routers tell each other how busy their links are.  Whats the best method to pass information between TCL scripts running on different routers?
Thanks!
Tim
Joe Clarke
Likely the easiest approach is to use SNMP traps from one router to another.  See https://supportforums.cisco.com/message/3713232#3713232 for an example.
