QPM 4.1.4 - Device in-Progress Discovery
Cesar TM
I have 2 devices with "In-Progress" status in Device in Discovery. I can´t delete or reimport/rediscovery this devices.
There are some script that manually delete these devices? I tried remove the common service, reboot the server, include same device with other ip address and also did not work.
Version QPM: 4.1.4 CS: 3.2
Hi Cesar,
Have you solve this issue? I am also facing the same problem using version 4.1.5.
Anyone from Cisco, kindly reply.
Arnold
Can Cisco reply this issue, I'm facing the same problem and posted since last year (Aug 21, 2011).
