Bookmark
Subscribe
1301
QPM 4.1(3) Device stuck in Discovery
CJasztrabTMW
I have QPM 4.1(3) and I have a large number of devices that are stuck in discovery.  I can't do anything with them. How do i either remove them or have then discovered?
chris
Nael Mohammad
Level 5
Level 5
What kind of devices are you trying to import to QPM that are stuck in discovery ?
To delete and re-import to QPM:
1. Go go QPM ---> Devices ---> Device Management --> Discovery Status and provide the screenshot for this page. Under the devices stuck in discovery, do you mean that it's "In Progress" ?
2. To delete the devices from QPM --> go to devices ---> device management --> device summary --> select all the devices you want deleted and then click "Delete Devices"
3. Attempt to populate by clicking "Import Devices to QPM".
Did you manage to solve this? I have the same problem with the same qpm version.
When I select device to delete it says "Device In-progress cannot be deleted"
nice regards,
Ivana
Have you solve this issue? I'm facing the same problem. Somebody from Cisco, kindly reply it.
I had to delete device by connecting directly to the database, and delete it from there
<http://:1741/dbreader/dbreader.html>
