02-16-2024 08:38 AM
Hello Experts,
Do we need to enable "ip rsvp bandwidth" on the interfaces for MPLS-TE? This is for the ASR920 platform. I have seen some examples of people using "ip rsvp bandwidth" on the MPLS interface without specifying the amount of bandwidth. My understanding is we need to enable "ip rsvp bandwidth" only when we want to reserve bandwidth for MPLS-TE tunnels on an interface. Can you please clarify if we need to enable "IP rsvp bandwidth" for the MPLS-TE on ASR920? I appreciate your response.
Thank you
02-16-2024 08:54 AM
The interface have BW and there is rsvp BW
If you dont specify the BW in ip rsvp command it inherit it value from real BW of interface.
MHM
02-16-2024 09:03 AM
Hi MHM,
Thank you for your response. Just to confirm we don't need to enable "IP rsvp bandwidth" on the interface for MPLS-TE if we don't want to reserve the bandwidth for tunnels.
Thank you
02-16-2024 09:06 AM
If you use dynamic path then you need ot if you use explicit path then no need.
MHM
02-16-2024 09:14 AM
Hi MHM,
Thank you for your response. Can you please explain why we need to enable "ip rsvp bandwidth" on the interface for the dynamic path? If you can refer to me a document, that would be great. I have tested in the lab with and without "IP rsvp bandwidth" on the interface and I have used dynamic path. I saw the same result.
Thank you
02-16-2024 09:17 AM
Can i see topolgy you use in lab
And you config
MHM
02-16-2024 09:50 AM
Hi @aljoush12 ,
"ip rsvp bandwidth" is required to enable RSVP on an interface. This is required for MPLS TE either you want to use dynamic or explicit path.
02-16-2024 12:22 PM
Hi Harold and MHM,
Thank you for your response. I did a quick test. So looks like it if we enable "mpls traffic-eng tunnels" on the interface, it automatically enables rsvp on the interface. If we enable "ip rsvp bandwidth" and don't specify bandwidth, rsvp will use 75% of the interface bandwidth for reservations.
interface GigabitEthernet0/0/22
mtu 9190
ip address x.x.x.x 255.255.255.252
ip ospf network point-to-point
ip ospf 1 area 0
bfd interval 300 min_rx 300 multiplier 3
end
#show ip rsvp interface gigabitEthernet 0/0/22
interface rsvp allocated i/f max flow max sub max VRF
Gi0/0/22 ena 0 0 0 0
mtu 9190
ip ospf 1 area 0
ip rsvp bandwidth
end
Gi0/0/22 ena 0 750M 750M 0
02-16-2024 12:38 PM
Hi @aljoush12 ,
I stand corrected. "ip rsvp bandwidth" is not required if you do not need to allocate bandwidth.
02-16-2024 12:44 PM
Now in TE tunnel specify tunnel BW to be for example 500
Abd config one path BW 300 and other 200 and check the dynamic path
Then change BW to he one path 200 and other 300
See if TE change the path depend on BW you config.
MHM
