"can not connect to aniserver."
r.sagredo
LMS 4.0
cal yo help me, please?
when we tried to use topology services, we receive the following message:
I hope you can help me.
Thanks!!
Joel Monge
Problem is likely that the hostname is not resolvable from the client machine.  You need to make sure the LMS server hostname and IP address are resolvable from the client.  You can either configure that on DNS or on the hosts file.
beside what Joel said, also the follwing TCP ports must be reachable from client to server:
    TCP 42342
    TCP 43242
for a test, try to telnet to these ports. If this fails, in most cases a firewall or access-list is blocking the connection.
