Radius AAA authentication issue on Cisco 3750E Switch
iamloki
After configuring all the radius setting on the switch and I get this error when I try to login with my username
Username:
Apr 14 06:47:56.597: AAA/BIND(00000026): Bind i/f
Apr 14 06:47:56.597: AAA/AUTHEN/LOGIN (00000026): Pick method list 'default'
Apr 14 06:47:56.597: RADIUS/ENCODE(00000026): ask "Username: "
Apr 14 06:47:56.597: RADIUS/ENCODE(00000026): send packet; GET_USER
Username: admin@greendc.local
Password:
Apr 14 06:48:12.677: RADIUS/ENCODE(00000026): ask "Password: "
Apr 14 06:48:12.677: RADIUS/ENCODE(00000026): send packet; GET_PASSWORD
Apr 14 06:48:27.835: RADIUS/ENCODE(00000026):Orig. component type = Exec
Apr 14 06:48:27.835: RADIUS/ENCODE(00000026): dropping service type, "radius-server attribute 6 on-for-login-auth" is off
Apr 14 06:48:27.835: RADIUS(00000026): Config NAS IP: 0.0.0.0
Apr 14 06:48:27.835: RADIUS(00000026): Config NAS IPv6: ::
Apr 14 06:48:27.835: RADIUS/ENCODE(00000026): acct_session_id: 28
Apr 14 06:48:27.835: RADIUS(00000026): sending
Apr 14 06:48:27.835: RADIUS/ENCODE: Best Local IP-Address <SWITCH/CLIENT IP> for Radius-Server <RADIUS SERVER IP>
Apr 14 06:48:27.843: RADIUS(00000026): Send Access-Request to <RADIUS SERVER IP>:1645 onvrf(0) id 1645/35, len 99
Apr 14 06:48:27.843: RADIUS: authenticator BD E5 63 55 DE B6 07 E7 - 51 3E 69 5D 38 16 58 0D
Apr 14 06:48:27.843: RADIUS: User-Name [1] 37 "admin@greendc.local"
Apr 14 06:48:27.843: RADIUS: User-Password [2] 18 *
Apr 14 06:48:27.843: RADIUS: NAS-Port [5] 6 0
Apr 14 06:48:27.843: RADIUS: NAS-Port-Id [87] 6 "tty0"
Apr 14 06:48:27.843: RADIUS: NAS-Port-Type [61] 6 Async [0]
Apr 14 06:48:27.843: RADIUS: NAS-IP-Address [4] 6 <SWITCH/CLIENT IP>
Apr 14 06:48:27.843: RADIUS(00000026): Sending a IPv4 Radius Packet
Apr 14 06:48:27.843: RADIUS(00000026): Started 5 sec timeout
Apr 14 06:48:27.852: RADIUS: Received from id 1645/35 <RADIUS SERVER IP>:1645, Access-Reject, len 20
Apr 14 06:48:27.860: RADIUS: authenticator 23 1C C6 48 C6 A8 DE FF - D3 13 38 44 95 1D 1B 60
Apr 14 06:48:27.860: RADIUS: response-authenticator decrypt fail, pak len 20
Anyone faced this issue?
11 Replies 11
marce1000
 - Looks like a bug , as an example note : https://bst.cloudapps.cisco.com/bugsearch?pf=prdNm&kw=response-authenticator%20decrypt%20fail&bt=custV&sb=anfr , none of those seem to match your platform however, but use latest advisory software version , check if that can help : https://software.cisco.com/download/home/282979365/type/280805680/release/15.2.4E10
 M.
I'm using the same version:
ciscostack#show version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.2(4)E10, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Tue 31-Mar-20 13:22 by prod_rel_team
This tutorial is a walk through of how to install Service Containers on ISR 4K routers. The containers are essentially KVM virtual machines. This tutorial will cover the commands needed, how to import that machine and how to configure the networking on the system to connect the virtual machine to
     - What's in the logs of the radius server , for that particular authentication ?
 M.
From Server Manager > NPS tab I see
A RADIUS message was received from the invalid RADIUS client IP address <Switch/Client IP>
Screenshot attached
Loki
 - Check client configuration on the radius server, from the link below it seems that if it is not defined by ip that should be advisable , else it must be dns-resolvable for the radius server : https://docs.microsoft.com/en-us/previous-versions/windows/it-pro/windows-server-2008-R2-and-2008/dd316135(v=ws.10)?redirectedfrom=MSDN
 M.
can you post the running configuration of your 3750 so we can see what you have configured ?
Config Attached
 - It seems that radius is apparently ISE-based, has the device been entered in ISE as NAD (network access device) with correct IP address ?
 M.
Hi Marce,
I dont remember doing this at all or even know about it. Would you suggest me to make some changes?
L
--> Apr 14 06:48:27.860: RADIUS: response-authenticator decrypt fail, pak len 20
This usually means that the passwords of the RADIUS server and the client do not match. Try and manually reenter the password on both:
server-private 10.0.64.33 non-standard key 7 104D000A0618 <-- cisco (decrypted), reenter that, do not copy and paste
ip radius source-interface interface <- use this and check that this interface IP is add in AAA server.
If there is NAT between device and AAA server use
radius-server attribute 4 ip-address
Or use both command.
