Reload Is Imminent
armando_97
Hi all, i'm new in this community.
I have a problem, i was trying to  reboot a switch 3560 but when i saw the next day i noticed that the reboot failed and every time now when i log in telnet i see the message "A reload is imminent".
I want to reboot the switch because i saw that the I/O memory is almost full.
Can you tell me if these 2 things are related. How can i solve the problem of the reboot message?
2 Accepted Solutions
marce1000
  - Check if someone scheduled a reload with show reload ; you can abort this with reload cancel .
  M.
                         >Now i have to try if i can do the manually reboot.
  Manual reboot can be done with just reload , note of course that after confirmation the device will
reload immediately
 M.
7 Replies 7
Leo Laohoo
What firmware is the switch running on?
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1)
marce1000
  M.
yeah the message is gone. Now i have to try if i can do the manually reboot.
Thanks ;)
I'd seriously consider upgrading the IOS.
12.2(25)SEB train is a very, very ancient version.
Unfortunately it is not a swithc I own.
I will suggest it to the owner
Thank you
reload immediately
 M.
