RESTCONF on an ios switch?
PatWruk
We are looking at automating some configuration checks across all of our switches, I created a quick script to run an api call and it works great on our newer switches running ios-xe, but we are running into an issue with our ios switches (Catalyst 2960x). even going down to the base of https://(ip)/restconf gives a 404 error.
I can't seem to find any non xe documentation on restconf, but the switch did support the restconf command and seems to have enabled it. Can someone point me in the right direction?
hi @PatWruk classic ios do not support restconf
Good luck
KB
Good luck
KB
PatWruk
That's what I was afraid of. Thank you @Kasun Bandara
