restore RME.DB ?
ddalessa
I am really in a bind. Supposedly, my rme.db file is corrupted. CiscoWorks no longer has any reference to our 300 routers we maintain. I have stopped the daemons, backed up the existing rme.db file & restored from a backup. Restarted the daemons but no luck. I am unable to retrieve the devices. Cisco tac is telling me without having the inventory file to IMPORT, I am faced with having to (re)input all 300 devices. I find this hard to believe. Why would I need to have the inventory export (CSV format) if I have successful backups taking place? Has anyone run into this issue? Am I relegated to having to input all 300 routers? Lastly, I have a local hosts file that allows the Ciscoworks to ping by a router host name. Is it possible to use a copy of this file to CREATE an import CSV file? What is the format of the file? I suppose I can add a router, export it to see. Do you think that would work?? Thanks in advance. Dan
5 Replies 5
yjdabear
Don't know about LMS 2.5, but here's the exported CSV from RME 3.5 (LMS 2.2). Don't know where serial numbers came from; certainly not entered manually.
; This file is generated by the export utility
; If you edit this file, be sure you know what you are doing
Cisco Systems NM data import, source = export utility; Version = 2.0; Type = Csv
; Here are the columns of the table.
; Columns 1 and 2 are required.
; Columns 3 through 19 are optional.
; Col# = 1: Name (including domain or simply an IP)
; Col# = 2: RO community string
; Col# = 3: RW community string
; Col# = 4: Serial Number
; Col# = 5: User Field 1
; Col# = 6: User Field 2
; Col# = 7: User Field 3
; Col# = 8: User Field 4
; Col# = 9; Name = Telnet password
; Col# = 10; Name = Enable password
; Col# = 11; Name = Enable secret
; Col# = 12; Name = Tacacs user
; Col# = 13; Name = Tacacs password
; Col# = 14; Name = Tacacs enable user
; Col# = 15; Name = Tacacs enable password
; Col# = 16; Name = Local user
; Col# = 17; Name = Local password
; Col# = 18; Name = Rcp user
; Col# = 19; Name = Rcp password
; Here are the rows of data.
router.domain.com,public,private,serial-number,"!{[NOVALUE]}!","!{[NOVALUE
]}!","!{[NOVALUE]}!","!{[NOVALUE]}!",telnet-passwd,enable-secret-passwd,enable-passwd,!{[NOVALUE]}!,!{[NOVALUE]}!,!{[NOVALUE]}!,!{[NOVALUE]}!,!{[NOVALUE]}!,!{[NOVALUE]}!,!{[NOVALUE]}!
I am actually trying to restore the rme.db and getting nowhere. I have done the following so far:
* /etc/init.d/dmgtd stop
* cd /opt/CSCOpx/databases/rme
* rm rme.db
* rm syslog.db
* rm rme.log (if it exists)
* cp orig/rme.dborig rme.db
* cp orig/syslog.dborig syslog.db
* chown bin:bin rme.db
* chown bin:bin syslog.db
* chmod 400 rme.db
* chmod 400 syslog.db
At this point, I am attempting to run the restorebackup.pl command with no success. I keep getting the following error"
Restore from backup '/var/cwbkup/92/rme/database' started at: 2006/04/13 18:56:4 0 Please see '/var/adm/CSCOpx/log/restorebackup.log' for status.
ERROR(1249): Cannot find generation in the root backup directory.
Any idea why? I have a valid backup in '/var/cwbkup/92/rme/database', but yet, the restorebackup process fails. I have tried just simply copying the backed up files over to /opt/CSCOpx/databases/rme with no luck.
Anyone have any ideas? This is so frustrating!
Dan
Please provide the exact command you are using to restore the backup.
Did you use this syntax?
/opt/CSCOpx/bin/perl /opt/CSCOpx/bin/restorebackup.pl [-force]* -s rme -d /var/cwbkup/92
*[-force] is optional
I finally got it restored using the following syntax:
./restorebackup.pl -f -d /var/cwbkup
Thank God
