Restrict access to management IP on RV 110 W
Ouss
so I just bought this cisco RV110W and i wanted to start to configure it. I have 2 Vlans and I want that the second VLAN has no access to the management IP. I could separate the two Vlans so the second can't access the management IP of the first VLAN ( 192.168.1.1) but still can access the management IP from the second VLAN (192.168.2.1). Is there a way to restrict access to management interface, so only Vlan 1 can see and modify the router config?
balaji.bandi
here is the configuration guide : you can add the IP address range who can have admin access for GUI :
Step 9. In the Allowed Remote IP Address field, click the Any IP Address radio button to allow remote upgrades to the router from any IP, or click the radio button beneath to enter a range of IP addresses that are allowed to remotely upgrade the router in the fields to the right.
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb2408-configure-firewall-basic-settings-on-rv110w.html
I hope this is what you looking i believe, if not please explain more.
BB
Thanks for the reply but it's not what I'm looking for.
The feature you mentioned is for remote IP out of the local the network. What i actually want is:
I have 2 vlans 192.168.1.x and 192.168.2.x
I want that the 192.168.2.x cant have access to the router GUI. While they cant  access to 192.168.1.1 they still can access to 192.168.2.1 which is the same.
In other words i want the management IP is accessible only from the 192.168.1.x ips
Or if i can have only one management ip and not for every vlan
I hope i explained better
