RME 4.0.6 - need more info about the "-view" paramater
philip.r.hayes
When using the "cwcli config comparewithbaseline" command, one of the parameters is "-view" followed by "name". We're having trouble figuring out what that is, how to use it, etc. I have uploaded a screen scrape of that section of the documentation.
Joe Clarke
I view is a fully-qualified name to an OGS group. For example:
CS@Server/System Defined Groups/Routers
Or:
RME@Server/User Defined Groups/Core Devices
Since the name may contain spaces, the argument should be quoted.
Can you elaborate on "OGS" group?
Object Grouping Service. It's the subsystem that allows one to create and evaluate groups. Each application comes with a set of System Defined Groups, and allows you to create up to 100 User Defined Groups.
