11-25-2008 08:21 AM
When using the "cwcli config comparewithbaseline" command, one of the parameters is "-view" followed by "name". We're having trouble figuring out what that is, how to use it, etc. I have uploaded a screen scrape of that section of the documentation.
11-25-2008 08:29 AM
I view is a fully-qualified name to an OGS group. For example:
CS@Server/System Defined Groups/Routers
Or:
RME@Server/User Defined Groups/Core Devices
Since the name may contain spaces, the argument should be quoted.
11-25-2008 08:39 AM
Can you elaborate on "OGS" group?
11-25-2008 08:41 AM
Object Grouping Service. It's the subsystem that allows one to create and evaluate groups. Each application comes with a set of System Defined Groups, and allows you to create up to 100 User Defined Groups.
