RME 4.1.1 - Sync on device problem for 55xx
interros09
Hi!
I have out of  sync for ASA 55xx (mismatch running with startup config).When I`m trying sync on device operation, result is FAILED.
Issue of this:
*** Device Details for ASA5520 ***
Protocol ==> Telnet
Selected Protocols with order ==> Telnet,TFTP,SSH,HTTPS
Execution Result:
CM0100 Copy PRIMARY Running Config to PRIMARY Startup Config on device failed Cause: Building configuration...
Cryptochecksum: 7f2f593f 8380cf94 21a7bbeb 2b185932
25269 bytes copied in 3.550 secs (8423 bytes/sec)[OK]
ASA5520# Primary Login Succeded
/ Primary Enable Succeded
I think is Bug!!!
Any suggest.
Thanks in advance.
Joe Clarke
This looks like a timing problem.  Unfortunately, there is nothing that can be done in LMS 3.0.1 to fix this.  If you upgrade to LMS 3.2, then the various CLI timers can be manipulated via a properties file.  You can upgrade to LMS 3.2 for free by downloading the LMS 3.2 eval from http://www.cisco.com/go/nmsevals .  If you install this eval on top of a licensed copy of LMS 3.0.1, you will end up with a licensed copy of LMS 3.2.
If the problem is still occurring after that, we can manipulate cmdsvc.properties to fix the timers.
