Hi!
I have out of sync for ASA 55xx (mismatch running with startup config).When I`m trying sync on device operation, result is FAILED.
Issue of this:
*** Device Details for ASA5520 ***
Protocol ==> Telnet
Selected Protocols with order ==> Telnet,TFTP,SSH,HTTPS
Execution Result:
CM0100 Copy PRIMARY Running Config to PRIMARY Startup Config on device failed Cause: Building configuration...
Cryptochecksum: 7f2f593f 8380cf94 21a7bbeb 2b185932
25269 bytes copied in 3.550 secs (8423 bytes/sec)[OK]
ASA5520# Primary Login Succeded
/ Primary Enable Succeded
I think is Bug!!!
Any suggest.
Thanks in advance.
