Using the out-of-the-box Banner template, RME 4.2 NetConfig reported deployment was successful on a CatOS 8 switch during both test runs. However, post baseline shows the MOTD is truncated and thousands of blank lines were inserted.
Is there any known issue or caveat with this template or NetConfig? I've attached both NetConfig job directories and pre/post switch config baslines to TAC case 612974651.
