RME Restore backup: URN_NOT_FOUND : urn "JRM" : Not found !!
during restore backup LMS2.2->LMS2.6I found in rme_ctm.log the following messages
[ Fri Feb 09 15:12:34 MET 2007 ],INFO ,[main],com.cisco.nm.xms.ctm.registry.CTMRegistryServer,49, Waiting to read the data ...
[ Fri Feb 09 15:12:34 MET 2007 ],INFO ,[Thread-0],com.cisco.nm.xms.ctm.registry.CTMRegistryHandler,454,Registry = {47002 [inventory
.ics.server-RMELogLevelChange]} {47001 [RMECSTMServer-RMELogLevelChange]}
[ Fri Feb 09 15:12:34 MET 2007 ],ERROR,[main],com.cisco.nm.xms.ctm.client.CTMCall,200,URN_NOT_FOUND : urn "JRM" : Not found !!
[ Fri Feb 09 15:12:34 MET 2007 ],ERROR,[main],com.cisco.nm.xms.ctm.client.CTMCall,209,URN_NOT_FOUND : urn "JRM" : Not found !!
[ Fri Feb 09 15:12:34 MET 2007 ],ERROR,[main],com.cisco.nm.xms.ctm.client.CTMClientProxy,195,URN_NOT_FOUND : urn "JRM" : Not found!!
What is this urn JRM?
anybody can help me
thanks
Leonardo
David Stanford
Did you restore backup succeed or fail?
It is common to see URN messages when processes are starting up and it doesn't necessarily mean there is a problem.
Are you restoring directly from 2.2 to 2.6??
yes... directly 2.2 to 2.6
however restoring goes now..
thanks.
