RME software Deployment issue
jobidondave
   I am using Cisco Works 4.0.0 and want to upgrade the IOS of a WS-C3750-48PS-S switch, I've added an IOS image from Cisco Website trought Ciscoworks RME repository jobs and worked fine.  Now, when I'm trying to deploy that IOS to the device, I'm getting a "no result"
Here the device result
10.9.0.20
File_Name : c3750-ipbasek9-mz.122-53.SE2.bin
File_Size : Unknown
Family : C3750
Version : 12.2(53)SE2
BOOTROM : Bootstrap program is C3750 boot loader
RAM : 147849216
Feature : IP|LAYER_3|SSH|3DES|MIN_DRAM_MEG=128
Media : RAM
Image_Type : SYSTEM_SW
Software_Name : C3750-IPBASEK9-M
SOURCE : flash:
UPGRADETYPE : ACTIVE
Flash Information
No Information
For some reason, there's no flash information available at that step but if I generate a detail device report for that same device, I'm getting the flash info.
Anyone can help on this one?
AFROJ AHMAD
Hi ,
Try the .TAR Image  on the Device and see how it works !!!
Thanks--
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
