Role-based access control – Views – Remove a command from a specific interface.
thinkabout
Environment:
I have the interfaces Ethernet 1/1, Ethernet 1/2 and Ethernet 1/3.
My goal is:
Manager can do the followings commands on Ethernet 1/1 and Ethernet 1/2:
  • Change the ip
  • See the description
  • Do shutdown
Manager can do the followings commands on Ethernet 1/3:
  • Change the ip
How can I remove the shutdown command only from the interface Ethernet 1/3?
Best regrads
Cristian Matei
   By using a different view.
Cristian Matei.
Cristian Matei.
No luck there :(.
  • I create view1 and view2.
  • Each view as working ok
  • Then create a superview1 it the both of the views give it to the user and didn't work.
