ROSA element manager enquiry ( connection using RS 232 interface )
Mohamad12345
Hi , I'm RF transmission engineer working in broadcast  station .
Our broadcast transmitters have only serial RS 232 interfaces .
We have ROSA element maanger unit in our site so i need to connect the broadcast transmitters to the ROSA element manager .
How can i do that ?
After finishing all installation is it possible to communicate with the broadcast equipements using web browser from our LAN ?
Michel Hegeraat
Level 7
Level 7
It would appear that if the ROSA supports your type of equipment then it would allow you to manage or at least monitor the device using a web browser.
This would mean that the ROSA hes a very good knowledge of how your equipment works and what questions or instructions it can give via the serial connection.
I have a very limited trust in general of this sort of equipment. Make sure you exact devicetype has support from cisco with its current software.
Cheers,
Michel
