CiscoWorks LMS 4.0 with ASR 1000 and ASR 9000
pefernandezc
Hello
I have many alarms with CWLMS 4.0. The alarms are OutOf Range Voltage, OutOfRange Temperature and OutOfRange Memory. For example:
I don´t know how eliminate this alarms for these equipaments. I am trying with Setting up the thresholds but nothing. Someone can help me?
Marvin Rhoads
The issue with Voltage sensors (and I suspect the others) is with the CWLMS product's polling incorrectly defining the expected range.
I had opened a TAC case for that very issue and Cisco engineering confirmed the problem. Bug CSCto53414 is open against this issue. (You can see it using Bug Toolkit.)
All you can do for now is acknowledge the (bogus) alarms.
Hope this helps.
Thanks mklemovitch for your response. It´s all extremely useful.
You're welcome. If you find the response helpful, please rate it.
