Router Always Restarted After Time Changing
SubnetWarrior
Hello Experts!
SO i have a strange problem that our company router always restarted after several hours. I have collected the logs after the routers resrtarted and each log have same pattern :
Log after restart 1 :
*Aug  3 13:58:23.591 UTC: %AAAA-4-NOSERVER: Warning: Server TEST is not defined.
*Aug  3 20:58:23.635 JKT: %SYS-6-CLOCKUPDATE: System clock has been updated from 13:58:23 UTC Sat Aug 3 2019 to 20:58:23 JKT Sat Aug 3 2019, configured from console by console.
*Aug  3 20:58:24.031 JKT: %VRRP-6-STATECHANGE: Gi0/0 Grp 1 state Init -> Backup
*Aug  3 20:58:24.431 JKT: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host X.X.X.X port 514 CLI Request Triggered
*Aug  3 20:58:24.435 JKT: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host X.X.X.X port 514 CLI Request Triggered
*Aug  3 20:58:25.519 JKT: %SYS-5-CONFIG_I: Configured from memory by console
*Aug  3 20:58:25.759 JKT: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=Y.Y.Y.Y, prot=50, spi=0x3EF0335D(1055929181), srcaddr=Z.Z.Z.Z, input interface=GigabitEthernet0/2
*Aug  3 20:58:26.135 JKT: %LINK-5-CHANGED: Interface Embedded-Service-Engine0/0, changed state to administratively down
*Aug  3 20:58:27.187 JKT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Embedded-Service-Engine0/0, changed state to down
*Aug  3 20:58:27.679 JKT: %LINK-3-UPDOWN: Interface SM1/1, changed state to up
*Aug  3 20:58:28.187 JKT: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M11, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sun 16-Oct-16 09:48 by prod_rel_team
*Aug  3 20:58:28.239 JKT: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Aug  3 20:58:28.251 JKT: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
Log after restart 2 :
*Aug  3 16:45:16.599 UTC: %AAAA-4-NOSERVER: Warning: Server TEST is not defined.
*Aug  3 23:45:16.643 JKT: %SYS-6-CLOCKUPDATE: System clock has been updated from 16:45:16 UTC Sat Aug 3 2019 to 23:45:16 JKT Sat Aug 3 2019, configured from console by console.
*Aug  3 23:45:17.039 JKT: %VRRP-6-STATECHANGE: Gi0/0 Grp 1 state Init -> Backup
*Aug  3 23:45:17.459 JKT: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host X.X.X.X port 514 CLI Request Triggered
*Aug  3 23:45:17.463 JKT: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host X.X.X.X port 514 CLI Request Triggered
*Aug  3 23:45:18.267 JKT: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=Y.Y.Y.Y, prot=50, spi=0x3EF0335D(1055929181), srcaddr=Z.Z.Z.Z, input interface=GigabitEthernet0/2
*Aug  3 23:45:18.551 JKT: %SYS-5-CONFIG_I: Configured from memory by console
*Aug  3 23:45:19.167 JKT: %LINK-5-CHANGED: Interface Embedded-Service-Engine0/0, changed state to administratively down
*Aug  3 23:45:20.219 JKT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Embedded-Service-Engine0/0, changed state to down
*Aug  3 23:45:20.763 JKT: %LINK-3-UPDOWN: Interface SM1/1, changed state to up
*Aug  3 23:45:21.211 JKT: %SYS-5-RESTART: System restarted --
*Aug  3 23:45:21.263 JKT: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Aug  3 23:45:21.275 JKT: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Aug  3 23:45:21.279 JKT: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
Log after restart 3 :
*Aug  4 05:20:21.711 JKT: %SYS-6-CLOCKUPDATE: System clock has been updated from 22:20:21 UTC Sat Aug 3 2019 to 05:20:21 JKT Sun Aug 4 2019, configured from console by console.
*Aug  4 05:20:22.107 JKT: %VRRP-6-STATECHANGE: Gi0/0 Grp 1 state Init -> Backup
*Aug  4 05:20:22.535 JKT: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host Y.Y.Y.Y port 514 CLI Request Triggered
*Aug  4 05:20:23.523 JKT: %SYS-5-CONFIG_I: Configured from memory by console
*Aug  4 05:20:24.143 JKT: %LINK-5-CHANGED: Interface Embedded-Service-Engine0/0, changed state to administratively down
*Aug  4 05:20:25.143 JKT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Embedded-Service-Engine0/0, changed state to down
*Aug  4 05:20:25.531 JKT: %LINK-3-UPDOWN: Interface SM1/1, changed state to up
*Aug  4 05:20:26.195 JKT: %SYS-5-RESTART: System restarted --
*Aug  4 05:20:26.247 JKT: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Aug  4 05:20:26.259 JKT: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*note : i have change some sensitive content.
Any idea ?
Leo Laohoo
If you have "sensitive content" then I'd recommend that you contact Cisco TAC because we are going to be asking for information they may contain information you might deem "sensitive" but is important to us troubleshooting the issue.
If you are still keen in continuing, then post the COMPLETE output to the following commands:
1. sh version (take away the router name but leave everything else alone);
2. dir
marce1000
 - Check current software version ; try a more recent version, if applicable.
 M.
