Router CPU High
Abdulu25
Hi, Can the High CPU experienced on my Router cause any network issue/Alerm on my network?
normally router CPU must be utilize, why you face high CPU?
balaji.bandi
yes it will impact on the processing, find out what is causing high CPU
show process CPU sorted | ex 0.00
some other tips ;
https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/15095-highcpu.html
BB
is this a theoretical/general question, or are you actually experiencing a problem ? Since the router is part of the network, high CPU utilization can definitely be caused by network 'issues'. Which router do you have (post the output of 'sh ver') ?
